I just got my internet upgraded from 40-50 down to 100 down
I am getting this speed using wifi, but when i use my wired connection using a powerline adapter that can handle 500 down i get around 30 down
I have reset the adapters to try to fix this, but it didn't work
There is a piece of software for the adapters that says i get 100 down
I am not sure what to believe, speedtest or the software
Any suggestions
Thanks
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
https://linustechtips.com/topic/259540-low-wired-speed-help/
could be that the software has a server much closer to you then speedtest
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/259540-low-wired-speed-help/#findComment-3541856
I just checked steam
http://gyazo.com/d2bc521070648c681aa38405e8690f25
On steam i am getting 50 mbps, still not 100
https://linustechtips.com/topic/259540-low-wired-speed-help/#findComment-3541875
Maybe there is something up where the Powerline adapters won't reach their full potential.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/259540-low-wired-speed-help/#findComment-3541877
Apparently it is common for powerline adapters to only reach 40-50 down :(
https://linustechtips.com/topic/259540-low-wired-speed-help/#findComment-3542082
The speed of a powerline adapter can be affected by multiple things.
1st the age and quality of your inside wiring
2nd the length of the cable in between each adapter
3rd other device that could cause interference
Have you tried changing the channel bandwidth ?
Main: Intel i7-4770K, MSI Z87 MPower, 2x 4GB G.Skills 1866MHz CL9, 2x Gigabyte R9-290X, Fractal Design XL R2, 2x Samsung EVO 250GB Raid0 and 2x 1TB Seagate Raid0, Top power 1000W 80+ Bronze, Asus PCE-AC68
Server: AMD FX-8350, MSI 970a-G46, 2x 4GB Mushkin 1866Mhz CL9, MSI 8600GT, Fractal Design Define R4, Samsung EVO 250GB and 6X 2TB Seagate RAID 10, EVGA 850W Supernova G2 80+Gold, 2x Intel GBe NIC
Router: Pfsense 2.2, Intel Core 2 Quad Q6600, Acer crap motherboard, 4x 2GB Samsung 800Mhz CL4, Fractal Design Node 604, OCZ Agility 2 50GB, Thermaltake 400W 80+, 2x Intel GBe NIC
https://linustechtips.com/topic/259540-low-wired-speed-help/#findComment-3542997
How would i do this ?
https://linustechtips.com/topic/259540-low-wired-speed-help/#findComment-3543027
Whats the brand and model of the powerline you have ?
https://linustechtips.com/topic/259540-low-wired-speed-help/#findComment-3562743
TP link TL-PA411
https://linustechtips.com/topic/259540-low-wired-speed-help/#findComment-3562755
I checked throughout the user manual guide and found no option to change the channels.
Also, i forgot to tell but its gonna work better if connected straight into a wall outlet. no powerbar/splitter
https://linustechtips.com/topic/259540-low-wired-speed-help/#findComment-3563468
It's connected into the wall outlet
https://linustechtips.com/topic/259540-low-wired-speed-help/#findComment-3563470
