I think it's a software thing. Giving the LEDs a gradually increased amount of power and then gradually lowering it to create a "breathing" effect. Not too sure, though.
Eien nante naito iikitte shimattar  /  Amarinimo sabishikute setsunai deshou
Dare mo ga hontou wa shinjitai kedo  /  Uragirarere ba fukaku kizu tsuite shimau mono
https://linustechtips.com/topic/258940-led-breathing/#findComment-3536184
so i have these nice leds but i want to do a breathing effect do anyone know how to go about that
Look up something called PWM - Pulse Width Modulation.
By varying the width of your "on" vs your "off" with a frequency of hundreds, maybe thousands of times per second, you can alter how brightly the LED lights up.
https://linustechtips.com/topic/258940-led-breathing/#findComment-3536208
But is there a simpler solution
Any controller will either use a DAC to directly control the voltage or PWM.
I think your best bet is to use a 555 timer IC, known and used by hobbyists for years.
It allows you to create simple circuits for this kind of stuff.
http://www.pcbheaven.com/circuitpages/555_Breathing_Pulsing_LED/ is an example of one such circuit; a breathing LED using a 555 kit.
https://linustechtips.com/topic/258940-led-breathing/#findComment-3547429
