Hi Guys,
This is my current build that I am working on http://uk.pcpartpicker.com/p/FhFFYJ.
Since this is my first build I don't exactly know what are the best parts and I mostly wing it.
So I would like to ask for help either to add or swap out some parts in this build to make it better. Or just use a different build altogether.
I am willing to spend around £1200-1500 ( $1900-$2400).
I should also mention that since this is my first build I am not really comfortable with over-clocking.
Thanks in advance.
https://linustechtips.com/topic/258627-help-with-a-build/
You need a beefier PSU.  Not my build of choice, but its not my choice.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/258627-help-with-a-build/#findComment-3532931
Personally i would not go with Asrock, I dont really trust them yet.
I prefer Asus, MSI and Gigabyte since they are older more reputable brands and i rarely see someone saying their motherboard dies.
Otherwise i think it looks good.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/258627-help-with-a-build/#findComment-3532954
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  (£244.94 @ Aria PC)
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler  (£64.90 @ CCL Computers)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  (£106.98 @ Scan.co.uk)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory  (£58.67 @ Ebuyer)
Storage: Crucial M500 240GB 2.5" Solid State Drive  (£65.00 @ Amazon UK)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  (£69.98 @ Aria PC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card (2-Way SLI)  (£259.98 @ Amazon UK)
Case: NZXT S340 (Black) ATX Mid Tower Case  (£57.35 @ Scan.co.uk)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (£87.44 @ Amazon UK)
Total: £1275.22
Generated by PCPartPicker 2014-11-27 13:50 GMT+0000
https://linustechtips.com/topic/258627-help-with-a-build/#findComment-3532974
Thanks guys,
One more question what is the advantage of two video cards that has less performance compared to one but high end one ?
Less as in 10% is not that much. Sli 970 is nearly the price of one 980 and although they dont scale lineair is still blows the 980 out the field.
Btw change the M500 to a MX100 same producer but the mx100 is newer and better.
https://linustechtips.com/topic/258627-help-with-a-build/#findComment-3533432
