Sorry about other people being rather unhelpful, it is clear that you just wanted some advice.
Here is what I would suggest. You haven't given any info on if you want peripherals too but I'm going to guess no. I am also guessing you are in the U.S.
http://pcpartpicker.com/p/15QgU
If you don't want that SSD you could ditch it and upgrade the video card to a 780 but I like the speed of an SSD.
The first step to insanity is believing in your sanity.
https://linustechtips.com/topic/25801-1500-build-ideas/#findComment-328135
isn't a 860w PSU too much?
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/25801-1500-build-ideas/#findComment-328302
An 860 PSU is a good choice for a GTX 770. They are power hungry as HELL! (seriously, even more power hungry than GTX Titan and 580!)
It may be a little too much but I can confirm that the GTX 770 will work with it unlike with some other PSU's
https://linustechtips.com/topic/25801-1500-build-ideas/#findComment-328635
Estimated Watts is only 430W so something arround 600W should also be more then enough and would save an other 100$
(\__/)
(")_(") This is Bunny.
https://linustechtips.com/topic/25801-1500-build-ideas/#findComment-331040
How does this look?
http://pcpartpicker.com/p/16iGq
change to a 650w PSU and save yourself some money :D
https://linustechtips.com/topic/25801-1500-build-ideas/#findComment-333351
http://pcpartpicker.com/p/16lMr
hope you dont mind but i future proofed it a bit
when it start to get slow, like in  one and a half or two years just buy another 770 and go 2 way sli
-Edit-
also try out the Cooler Master Storm Enforcer
Its a mid tower case but you'll have PLENTY of space
Insomnia!
Taking down airplanes with gameboys
https://linustechtips.com/topic/25801-1500-build-ideas/#findComment-333900
-Edit-
Thanks for the help I think I will go with the Cooler Master Storm Enforcer and your Build. Thanks. :)
https://linustechtips.com/topic/25801-1500-build-ideas/#findComment-334729
http://pcpartpicker.com/p/16SGD
 Going AMD saves money.  It's worth it
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/25801-1500-build-ideas/#findComment-338850
