I got a gtx 980 recently, but im having difficulty overclocking it practically. It has automatic clock speed changer, but that means it maxes out at like 1100, which is really low for this card. I can get it to go faster by using gpu tweak, but that isnt dynamic, which is what i want. And also, gpu tweak maxes out at 1400, which is lower than the boost speed of the g1 gaming model. I have the strix model, and expect that it should be able to achieve the same. What can i do to overclock this card effectively, and practically?
https://linustechtips.com/topic/257909-gtx-980-overclocking-issues/
Have you tried using MSI Afterburner? That is what I have used on my cards including a 980 Strix.
What are your settings like in GPU Tweek? Are they matching up with what GPU-Z says?
Mine does that too
Current Rig:   CPU: AMD 1950X @4Ghz. Cooler: Enermax Liqtech TR4 360. Motherboard:Asus Zenith Extreme. RAM: 8GB Crucial DDR4 3666. GPU: Reference GTX 970  SSD: 250GB Samsung 970 EVO.  HDD: Seagate Barracuda 7200.14 2TB. Case: Phanteks Enthoo Pro. PSU: Corsair RM1000X. OS: Windows 10 Pro UEFI mode  (installed on SSD)
Peripherals:  Display: Acer XB272 1080p 240Hz G Sync Keyboard: Corsair K95 RGB Brown Mouse: Logitech G502 RGB Headhet: Roccat XTD 5.1 analogue
Daily Devices:Sony Xperia XZ1 Compact and 128GB iPad Pro
