Would you be gaming, or do you need a lot of space?
Seeing that 500GB HDD, I'm not presuming so..
And yes, I did go with the MX this time because of the budget.
Not as sexy as the EVO but..
PCPartPicker part list: http://pcpartpicker.com/p/M232TW
Price breakdown by merchant: http://pcpartpicker.com/p/M232TW/by_merchant/
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor  ($94.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H81M-H Micro ATX LGA1150 Motherboard  ($39.99 @ Newegg)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory  ($57.99 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($94.97 @ SuperBiiz)
Video Card: Sapphire Radeon R9 280 3GB DUAL-X Video Card  ($169.99 @ Newegg)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($25.99 @ Newegg)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply  ($29.99 @ Newegg)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  ($13.99 @ Amazon)
Total: $527.90
Generated by PCPartPicker 2014-11-25 20:56 EST-0500
#SAMSUNG  "provided us 4 1tb ssds so we could run the whole site off solid state." - LinusTech
#GALAXY
#ATIV
HI AND WELCOME TO THE FORUMS, hope you have fun :)
as for your build..
a 4gb r9 270 i pointless, games today are barely using full 2gb and it does not have a wide enough memory bandwith to use all dat memory at onece, stick with a 2gb model.
as for CPU cooler i would go with the Hyper T4, as it cools better than that one and mounts natively on AMD so you dont have to mount a different backplate.
if you got 4gb i assume you wanna thow in a second 4gb stick later, am i right?
as for the motherboard i would go with THIS ONE    because it has a newer and better chipset, and should OC better.
very nice budget build, welcome to glorious PCMASTERRACE
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
So far none of the AMD MoBos here have sufficient power delivery for demanding FX CPUs. You really want at least the GA-970A-UD3P. However, I still think going with an intel build would be better. For the price, I would do this:
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($168.99 @ NCIX US)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($27.99 @ Newegg)
Memory: Team Dark 8GB (1 x 8GB) DDR3-1600 Memory  ($67.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Newegg)
Video Card: Asus Radeon R9 270 2GB DirectCU II Video Card  ($135.99 @ Amazon)
Case: Fractal Design Core 2300 ATX Full Tower Case  ($34.99 @ NCIX US)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($43.54 @ SuperBiiz)
Other: Internal USB 3.0 to 2.0 ($2.45)
Total: $531.93
Generated by PCPartPicker 2014-11-25 21:01 EST-0500
The R9 270 and 270x have the same architecture, the core clock is the only thing different and so at the same clock speeds, they'll perform identically. The regular 270 can also be overclocked as high as an R9 270x, so there's really no reason to get the X version. I only gave you a single stick of memory in case you want to add in a second stick, and you really don't ever need an optical drive. Heck, even for installing the OS you can use a USB flash drive. Overall I would much prefer this build. Again, there's no point in spreading out the purchases. Buy all at once or not at all.
Little bit over budget, but i squeezed in an SSD.
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($59.94 @ SuperBiiz)
Memory: Kingston Fury Series 8GB (2 x 4GB) DDR3-1866 Memory  ($67.57 @ SuperBiiz)
Video Card: MSI Radeon R9 270X 2GB Video Card  ($149.99 @ Amazon)
Case: NZXT Source 210 Elite (Black) ATX Mid Tower Case  ($41.99 @ Directron)
Total: $559.44
Generated by PCPartPicker 2014-11-25 21:08 EST-0500
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  ($89.99 @ Amazon)
Motherboard: ASRock FM2A55M-HD+ Micro ATX FM2+ Motherboard  ($49.99 @ Newegg)
Memory: Patriot Signature 8GB (1 x 8GB) DDR3-1333 Memory  ($73.99 @ Amazon)
Storage: Western Digital  500GB 3.5" 7200RPM Internal Hard Drive  ($51.00 @ Amazon)
Video Card: Gigabyte GeForce GT 730 2GB Video Card  ($59.99 @ Newegg)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($39.99 @ NCIX US)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($32.99 @ NCIX US)
Optical Drive: Asus DRW-24F1ST DVD/CD Writer  ($14.98 @ OutletPC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($84.15 @ SuperBiiz)
Total: $497.07
Generated by PCPartPicker 2014-11-25 21:32 EST-0500
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
