hey guys, ive been wanting to build my first pc but im not sure if my cooler is compatible with my motherboard, ram and case.
here's the link to pcpartspicker: http://pcpartpicker.com/p/6bY6yc, please note that the case has to be an aercool strike-x xtreme instead of this one since they didnt have the xtreme version.
thanks and have a nice day
~max
https://linustechtips.com/topic/257348-is-my-fan-compatible/
looks good to me. enough clearance for everything. nice pick.
you may want to go with 2x4gb of ram instead of 1x8gb. its better dual channel than single.
dont worry about the Cpu cooler, its will clear the ram if you use the 2 and 4 slot.
may your framerates be high and your temperatures be low. #pcmr
https://linustechtips.com/topic/257348-is-my-fan-compatible/#findComment-3519626
