So every now and then i buy an upgrade for my system and its around that time again.  Below is the break down of my machine.  What would be the smartest upgrade to get more performance out my machine would you all think?
AMD FX 8350 @ 4.4ghz
ASUS M5A99X Evo
MSI GTX 680 Lightning
G.SKIL Sniper 1866 4GBx2
Corsair HX850W PSU
Corsair A70 Air Cooler
Mushkin 120GB SSD
Fractal Define XL R2 Case
3x1TB WD Black HDDs
Intel 4790k • Asus Z97-A • Gigabyte GTX 970 Windforce • G.Skill 1866 4GBx2 • Corsair HX850W PSU • Noctua NH-D15 Air Cooler • Intel 530 120GB SSD(OS) • 1TB HDD(Games) • Cooler Master HAF 912 • Logitech G15 Key • Razer Abyssus Mouse • Asus 24in 144hz VG248QE
https://linustechtips.com/topic/25702-advice-on-upgrade/
why the shit would you upgrade? the system is quite good even though it might be little older...
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/25702-advice-on-upgrade/#findComment-326423
honestly man you dont need one
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/25702-advice-on-upgrade/#findComment-326429
Older? not at all, you could buy a Swiftec H220, that way you can OC further, and add a GPU block later and expand it, also you could get a sound card if you have decent headphones/headset.
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
https://linustechtips.com/topic/25702-advice-on-upgrade/#findComment-326435
You could upgrade to a haswell 4770k? Or get some form of a liquid cooling loop?
Desk: monitors 3x Asus VE248h(eyefinity), Keyboard Cm Strom Trigger(mx red), Mouse Corsair m65, Headset Audio Technica ATH-M50
Black Friday 2013 Build: i7 4770k, Gigabyte Z87X UD5H, 16gb Corsair, Msi R9 290, Corsair Axi 760, Corsair 750D, 2x intel 530 240gb ssd, 2x Seagate 400gb
Older Machine amd x640, msi 760g mobo, 8gb gskillz, Sapphire 6870, Corsair hx650, Cooler master haf 922, ocz agility 3 120gb ssd || HTPC: i7 3770k, shuttle xpc z77, 16gb gskillz, Asus GTX 650 ti, intel 120gb msata ssd
https://linustechtips.com/topic/25702-advice-on-upgrade/#findComment-326446
What monitor have you got? If it's 1080p you don't need to upgrade your gpu. That will last you a while. I would say wait for the HD9000 series. You could upgrade now but you probably won't get a noticeable performance increase. The same is kind of true for upgrading to Haswell. If you reckon it makes sense to spend a large some of money on something you won't really notice, go for it.
If you really want to upgrade something, get yourself a nice mechanical keyboard or a decent mouse or something (as long as you don't already have one). What sound solution have you got? Decent headphones or speakers?
Rig: i7 2600K @ 4.2GHz, Larkooler Watercooling System, MSI Z68a-gd80-G3, 8GB G.Skill Sniper 1600MHz CL9, Gigabyte GTX 670 Windforce 3x 2GB OC, Samsung 840 250GB, 1TB WD Caviar Blue, Auzentech X-FI Forte 7.1, XFX PRO650W, Silverstone RV02 Monitors: Asus PB278Q, LG W2243S-PF (Gaming / overclocked to 74Hz) Peripherals: Logitech G9x Laser, QPad MK-50, AudioTechnica ATH AD700
https://linustechtips.com/topic/25702-advice-on-upgrade/#findComment-326505
I have a 1080p monitor and i'm only really looking to upgrade the current setup to add something not change over to anything else.  Sound Card is a good idea i have 5.1 Rocat Kave headphones.  I've always wanted to do water cooling but i have have enough trust to put those AIO units in my system if i was like in the 1% bracket that has an issue with their unit and it leaks or something i don't have the money to put this type of rig together again.  I do have an Old Logitech G15 keyboard and was thinking about getting a ducky or a Corsair keyboard but i can live with what i have i'm more about upgrading to get performance gains but i do have keyboard on my mind.  My mouse right now is razer abyssus and its right small i'm a claw mouse type of person the big bulky ones i'm not to keen on.
https://linustechtips.com/topic/25702-advice-on-upgrade/#findComment-327175
O and my Monitor is a Samsung P2350 and i've had it for quite a while i wouldn't mind updating that but i would only spend enough money for another 1080p monitor so i don't even know if its worth it.
https://linustechtips.com/topic/25702-advice-on-upgrade/#findComment-327190
Eyefinity or nvidia surround!
https://linustechtips.com/topic/25702-advice-on-upgrade/#findComment-327590
Peripherals will give a definite noticeable upgrade. You can't go wrong with satisfaction when getting something you will physically work with.
https://linustechtips.com/topic/25702-advice-on-upgrade/#findComment-341976
