Hey Guys!
I want to get into Water Cooling and start off with a custom loop for my CPU. More parts will be added later. I chose following components:
http://www.aquatuning.de/AtsdCartSave/load/AtsdCartSaveKey/1f50d588ed51561d62cf49946536fcd1
http://www.mindfactory.de/product_info.php/EK-Water-Blocks-EK-Supremacy-EVO-Full-Nickel_975137.html
Are those components compatible to each other?
My budget is at about 300€ (370$), maybe a little bit more if worthwhile.
Thanks in advance
https://linustechtips.com/topic/256606-getting-into-water-cooling/
If space isn't an issue, stick with the thicker rad - it will give you slightly better cooling performance.  As BirdyTheMighty said, a 120 or 140mm rad is enough for just a CPU, but sticking with the 280mm rad will leave you room for future expansion.  One thing you will run into with 3/8ID tubing and that specific pump is trying to get the tubing over the barb.  You'll need to soak the end of the tube in boiling water for about 10 seconds, stick a pair of needle-nose pliers inside the tube, and spread the pliers to stretch the tubing.  You might have to do that a couple times, but you'll get it to fit.  I think Linus actually does this in one of his build logs if you need a reference
"There are 10 types of people in the world: those that understand binary and those that do not."
CPU:  4790K @ 4.7GHz  Motherboard:  ASUS Maximus VI Formula  RAM:  32GB Corsair Vengeance Pro 2400MHz  GPU:  (2) GTX 780 Poseidons in SLI  Case:  NZXT H440  Storage:  (2) Samsung 840 EVO 500GB SSDs and (1) 4TB WD Black HDD  PSU:  EVGA Supernova G2 850w  Cooling:  Custom loop - Koolance 380i CPU block, (built-in waterblocks on GPUs), Alphacool VP655 pump, (1) 360mm XSPC radiator, (1) 240mm XSPC radiator, Bitspower 150 reservoir
just for a cpu any rad 120 is more than enough,
true, but if you going for a custom loop anyway, why not go with a 240 or 280?
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
Didn't work out like I wanted it to, so here's a screenshot.
Would I be better off with a thinner radiator? I want to mount the radiator and reservoir outside of the case, so space should be no issue.
I think you might want to check out the 45 thick ones dude. What is your case? I'm working on my full custom loop atm. I received my Alphacool 240 and 360 rads today both 45 thick. I considered the 60 but was advised it might be too big. Unless you are keeping it in a basement like in a 900d or something I doubt you're gonna have room for that in most cases mounted to the top. The 45 is already pretty thick. Anyways if you have any questions let me know as I just got 2 of their products today.
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
