Cable stupidity
By
Giganizer300PRO
in Displays
in Displays
Solved by Glenwing,
So what you are saying is: if I get HDMI 1.3 or up, the Windows might not detect the full resolution, but I can change it in NVIDIA Control panel and it will work just fine, I will be able to use the monitor's full resolution - 2560 x 1080?
Yes.
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
Posted in Servers, NAS, and Home Lab1
play_circle_filled
Latest From ShortCircuit:
