I am building my 5th computer this time with amd fx8350, radeon 7850, and 8gb gskill. So i tested the gpu and it works and the psu works everything is plugged in and all that i can think of is the harddrive or cpu so how would i test which one it is without any spare parts and the i get no signal on my monitor when turning it on.
https://linustechtips.com/topic/256125-no-signal-when-building-computer/
use the hard drive on another computer if you have one.
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
does everything inside the case work\? fans etc..
Specs
CPU-Intel I7 4790K- @ 4.5Ghz / Mobo - Asus Maximus Hero VII / GPU - GTX 980 @ 1592MHz / RAM - 16Gb Corsair Vengeance Pro @ 2400Mhz / Cooler - Corsair H105 / SSD - Samsung 250gb 840 EVO / HDD - 2x 2tb Seagate/3x 3tb Seagate / PSU - Corsair RM1000 / Keyboard - Corsair K70 / Mouse - Corsair M65 / Case - Custom Glass panel Corsair Obsidian 750D -  Still saving for upgrades =)
First off I would try pulling out the RAM and re seating it. Also that chip doesnt have intagrated graphics so I'm assuming your board doesnt have a vidio output, try different video outputs on your GPU. You are not seeing anything at all on the display? Good luck!
