When i turned on my PC this morning i got CPU fan error. checked every single cable but nothing..
When i turn my PC on the light on H100i flashes spins the extra fans and then turns off however the fans on the radiator are still running fine but it doesn't run any other fans connected to it.
cant see the pump speed in BIOS, pump is not showing up in Corsair Link either
any help would be great
Images:
https://linustechtips.com/topic/255863-h100i-issue/
Happened with me as well, seems like my pump died. Corsair replaced it quickly under warranty. Contact Corsair.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/255863-h100i-issue/#findComment-3502203
