Need help with powerline networking
Solved by Johannes_Lazor,
The powerline adapters is almost as good as cables, But there is one main disadvantage, They work like a switch so you wont use much of your router,
The response time is close to neglectable, It is only 1 or 3ms.
You should have the router to a 1000mbit/s(input) and you can mix and match however you want, But if you have 2x500mbit/s Or 5x200mbit/s adapters(Or some other match as long as the total bitrate doesnt exceed 1000mbit/s)(outputs) you will never see a slowdown when someone else is using another computer.
