i restarted my computer and now my hard drive is not showing up my ssd is and thats how i git to windows, i have tried different sata ports and cables, and when i go to the disk mang. and search for it it loads and then shows my hard drive in windows but the when i try to click on it, it just frezes and then it goes not responding, then i restart my computer and it still not there, and help would be great. :)
Main Rig: i7 4770k @ 4.2Ghz, sabertooth z87, Gtx 980, hx 750 ,16gb vengeance pro, 120gb kingston ssd, 3tb segate
https://linustechtips.com/topic/255361-hard-drive-not-showing-up/
Can you post some screenshots of your drive list?
Also go to the Disk Defragment and see if it's there
it doesnt show up in disk defragment and its not in my drive list
Probably died. :(
System 1: Thermaltake Element Q - Thermaltake 220W SFX - Asus AT5IONT-I mini-ITX - Intel® Atom™ D525 onboard 1.8GHz Dual-Core HT - Integrated NVIDIA® ION™ - 2x 2GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
System 2: Thermaltake Element Q - Thermaltake 220W SFX - Asus E2KM1I-DELUXE mini-ITX - AMD E2-2000 onboard 1.75GHz Dual-Core - Integrated AMD® Radeon HD 7340 - 2x 4GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
Building: Bitfenix Prodigy Black - Corsair AX860i - Asus Maximus VII Impact - Corsair Hydro Series H100i - Intel® Core™ i7 4790K - Asus Matrix Platinum GTX 980 4GB - Corsair 16GB Dominator Platinum 2x 8GB DDR3 2400MHz CL10 - Samsung 1TB EVO 840 Series
does it show up in bios
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
it does not show up in bios and i have tried different cables and ports, and when i search for the drive in disk mang. it found it and i could go in to the drive, but then when i try to close disk mang. everything just freezes
not sure sorry
}else{
You could try going into Device Manager, and uninstalling the driver. Then, it should reinstall a fresh driver.
After that, click the start button and right click on "My Computer". Click "Manage". Now, click storage, and click disc management. It should show up as unpartitioned, simply right click on it and create a new volume. Hope I could help..
will all of my stuff still be on it though
Your stuff will be on it, your controller on the drive itself is probably shot.
how would i know for sure if it was and what could i do about it
If it doesn't work when you delete and have it reinstall the drivers, and doesnt show up after, it may be shot. Creating the new volume is taking part of the hdd and dedicating all of it or some of it to a certain label.
what drivers should i uninstall and reinstall
There's not much you can do about it. And I'm not sure how you could make sure, this is pretty textbook. You could send it in to a recovery shop, but that'd be incredibly expensive.
