I attempted to overclock my 6770 using msi afterburner, upon doing so my screen went black then blue screened. Rebooted PC after the hd not reading reset the clock speeds and then went to play civ 5 and noticed that the screen would tear ever now and again. Anything I can do?
https://linustechtips.com/topic/25533-6770-oc-problems/
Happens even idling
Have you tried turning vsync on?
https://linustechtips.com/topic/25533-6770-oc-problems/#findComment-323913
As ive got the same card. WHAT DID YOU DO? I normally go to 900mhz or 925mhz if its a cold day(the only reason its good to be in Britain). Any higher and drivers shit out every few seconds. I dont really touch the memory clocks as they cause the drivers to crash quite a lot.
Listen if you care.
https://linustechtips.com/topic/25533-6770-oc-problems/#findComment-327227
