Spex:
CPU/APU: AMD A6-6400K
CPU Cooler: Cooler Master 120V Seidon
Motherboard: Asus A88XM-A
GPU: Asus Radeon HD 7770
HDD: A. WD Black 750GB 2.5"
          B. Segate Momentius 120GB 2.5"
          C. Fujitsu 120 2.5"
PSU: Sentey 725W Modular
RAM: Kingston HyperX Black 8GB(2x4GB)
OS: Windows XP
i turned it on and i get no results i even tryed using another monitor just to double check if it was the monitor.
https://linustechtips.com/topic/254904-first-pc-build-not-working/
"i turned it on and i get no results i even tryed using another monitor just to double check if it was the monitor."
Did your PC show any signs of life, such as LED's turning on, or fans powering up? If not, check your PSU switch. I was worried for about 5 minutes on my first build when it wouldnt power on, but it only turned out to be the PSU power switch.
Let me know :)
Let me know :)
Everything that has a light is on
Do fans spin?
Yes
is there a light on your motherboard lighting up ?
Yes
Ok so try to take out one of the ram sticks and see if it boots if not try it with the one you took out and see if it boots if not then you might have faulty ram.
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
i have this cable that cannot be removed from the PSU
that's the one looks like it comes apart to make it into a 4 pin try it out!
Also I recommend putting you ram in the same color slots so it can run in dual channel ,so like the 1st and 3rd slot or 2nd and 4th. I could not tell you the tech facts of dual channel but I know it's better.
........ I may be picking at your build but...... why is the cooler upside down. It bothers me  <_<
You need better cable management and make sure to plug your gpu into your psu using a PCI-e cable.
i noticed that i put that upside down like 20 minutes ago
