Gpu upgrading help
Solved by Muffinmaddness,
get an r9 270 £105.62 Inc VAT
http://www.scan.co.uk/products/2gb-xfx-radeon-r9-270-boost-28nm-5600mhz-gddr5-gpu-900mhz-boost-925mhz-1280-streams-dp-dvi-hdmi-plus
or a
r9 280 £148.84 Inc VAT
or if you want to spend abit more
a GTX 970 £251.96 Inc VAT
the first one will be perfect for you're set up
the second if you need a little more power later on
the third is just beast and will last you a good while =)
