Overclocking Help
Solved by LogicalDrm,
You have 4770K. Deal with the thing that most likely aren't going to get it up to 4.8GHz. Most of those chips are in range of 4.3-4.4GHz. You need really good luck or really impressive cooling or both to get anywhere near those numbers.
This is general guide for Gigabyte mobos. Its for older chipset but works for Z87 boards as well.
As and off topic notice, you need to edit your sig to follow CoC. It has to be max 3 lines long. If you wan't to list whole system, use spoiler tags.
