please help me .
i recently using r9 280x at my computer . so i using dvi to d-sub converter . but nothing appear in my monitor . is my monitor not compatible ?
What model monitor have you got?
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/254205-need-help/#findComment-3482146
are you using a dvi d or a normal dvi port?
Corsair 750D | Asus Crosshair V Formula-Z | FX 9590 | Kingston HyperX 16GB@1866MHz | MSI R9 290X Lightning | Seasonic 1050W Platinum | 2x WD 3TB Green HDD | Samsung 840 Pro 256GB SSD | Crucial 512GB SSD
Alphacool XT45 360mm | Alphacool Monsta 280mm | Silverstone AP121 | Silverstone AP141 | EK Supremacy Elite | EK ASUS C5F-Z | EK R9-290X Lightning | EK 3/8-1/2 Nickel | XSPC D5 Acrylic Tank | Primochill 3/8-1/2
https://linustechtips.com/topic/254205-need-help/#findComment-3482151
im using dvi-d
dvi-d on has only digital signal. d-sub or vga is analog. so I think your out of luck.
time for a new monitor maybe
https://linustechtips.com/topic/254205-need-help/#findComment-3482248
if im using hdmi to d-sub will work ?
https://linustechtips.com/topic/254205-need-help/#findComment-3482282
yes, it will work but you will not get sound over the hdmi any more. if that applies to you that is.
https://linustechtips.com/topic/254205-need-help/#findComment-3482293
oh great its better. rather than buying new monitor :)  Thanks man
sweet, no worries
https://linustechtips.com/topic/254205-need-help/#findComment-3482317
