Motherboard USB Help
Solved by acolombo,
So the Mobo i am looking at has no USB 3.0 header, but it has plenty of USB 2.0. How badly would the speed be effected if I were to buy an USB 3.0 to 2.0 header, would it be worth it, or should I get a new mobo? I have a Case with a front usb 3.0 and i want to use it.
Do you have any USB 3.0 device? What kind of USB 3.0 devices do you have?
I think it only depends on how often do you use USB 3.0 devices, then you could consider to buy a PCI USB3.0 expansion card for your current motherboard, a whole new motheboard or only an USB 3.0 to 2.0 adapter...
