im looking for a just some good case fans. i want to push a lots of air. im looking for a 200mm and 120mm. also dont want to break my wallet with the purchase. there are just so many option cant decide so im looking for some help. thank you im open to all suggestions
https://linustechtips.com/topic/25359-good-case-fans/
They have 200 mm fans, but they are OEM, you can buy them from their site.
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
https://linustechtips.com/topic/25359-good-case-fans/#findComment-321713
Will a 180mm fit? Because a 180mm Silverstone Air Penetrator is considerably better than any of the 200+mm fans. If not, then BitFenix is the only good option at 200 and 230.
In case the moderators do not ban me as requested, this is a notice that I have left and am not coming back.
https://linustechtips.com/topic/25359-good-case-fans/#findComment-321757
I have had good luck with my xigmatec 200mm fans, but from reading on here there isn't a huge difference between any of the 200mm fans. Also +1 for the af120's I just got mine today they look fantastic and are very quiet.
My Timewaster: i5 3570k @ 4.4GHz 1.19v, Asus P8Z77-V, Noctua NH-D14, Sapphire Radeon HD 7850, 16 GB Corsair Vengance, 128GB Samsung 830 SSD, HAF 912, Logitech G710+, G700
https://linustechtips.com/topic/25359-good-case-fans/#findComment-325350
