Upgrading Computer Audio Interface for Guitar
Hello.
I am an aspiring guitar player and am thinking about upgrading the audio interface for my guitar and computer. I plan to use my guitar to play and record with Garageband. (Relax people! I dual boot! My daily driver is windows and recently installed OSX to test out :-P).
I tried a 1/4" to USB cable, but the audio quality kinda sucked, and there was a lot of latency.
Then I looked into the Focusrite Scarlett 2i2 USB audio interface.
http://www.amazon.com/gp/product/B005OZE9SA/ref=s9_simh_gw_p23_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=desktop-1&pf_rd_r=145DTM06XBMKHQ86R2BJ&pf_rd_t=36701&pf_rd_p=1976649162&pf_rd_i=desktop
Does anyone have this? I have many questions.
Is this the best route for getting into recording? Is this a DAC too? I have Beyerdynamic DT 880s and a Fiio E10 DAC. Would this new interface replace my DAC? Is it better than the E10?
Any advice or suggestions are much appreciated. I don't know much about the recording area of computers/instruments/etc. And would like to learn.
Thanks!
I have the 2i2. It has been pretty great so far, though getting everything tweaked to work perfectly took a little time. Latency wasn't too bad to start out, but I got it down to pretty much nothing. I finally got it worked out so I could even get the audio from amplitube working at the same time as the rest of the audio, so it's possible to play and watch a movie at the same time. Get a good quality cable for your guitar though, you'll pick up some noise.
Ok. Cool guys. Thanks.
What did you end up having to do?
I have the 2i2, but haven't used it for recording, just as a volume knob. It's a good piece of kit though, well built and no interference or anything. (Using Livewire TRS jacks)
From the reviews I've read the hardware is great, the drivers abit iffy though. . . but as I say I haven't used it for recording so can't comment on that.
I don't think it's a DAC, as DACs are more geared towards the output of sound, this would be counted as a DAW (Digital Audio Workstation) where latency is important.
CPU: Ryzen 5 3600 | Cooler: Stock | RAM: 16GB Hyper Fury X RGB | GPU: RTX 2080 Super FTW3 | Motherboard: Gigabyte Aorus Elite| PSU: Corsair RM850x
Storage: WD SN750 500GB / 850 500GB Samsung Evo /  | CASE: 570X | Display: Dell u2414h  | KEYBOARD: Corsair K70 | MOUSE: Corsair M65
It was a lot of messing with playback and recording devices. I had a bit of an audio mess, still kinda do. ASIO is great for audio, but is difficult to manage sometimes because of it taking exclusive control through one application. I got an essence stx a while ago for my sennheiser hd650, then used coax out on the stx to A schiit bifrost. Jriver media center runs well with ASIO, so I put it in. Then the 2i2 had it's own ASIO diver. So it was a lot of trial and error with drivers between hardware, and selecting default devices and disabling others in the sound panel. It was a pain, but well worth it. I can watch anything from movies to YouTube while a guitar is running cranked through amplitube, all into headphones so there are zero noise complaints.
Once you get it dialed in, it's well worth owning.
