My epic summer project
Go to solution Solved by sabot,
That looks like a good item. If your question is solved, mark the solution that helped answer your problem. That capture device looks like it will preform well and capture your vhs tapes. :)
My parents have tasked me with an epic mission dun dun dun. To convert all of our home videos (VHS) to dvd. I did a count and we have 300+ntapes does anyone have recomendations on a good capture device I was looking at http://www.radioshack.com/product/index.jsp?productId=3875555#tabsetBasic and any good archival dvds and would any extra software be needed I was planning on getting sony dvd maker the home version of vegas for my youtube channel anyway.
https://linustechtips.com/topic/25313-my-epic-summer-project/
Would something like an easycap work? They are very cheap, sub 30 dollars and if you look hard enough they exist for 5 or 6$. They can cap the same things and come with some software for using it to capture stuff.
Desk: monitors 3x Asus VE248h(eyefinity), Keyboard Cm Strom Trigger(mx red), Mouse Corsair m65, Headset Audio Technica ATH-M50
Black Friday 2013 Build: i7 4770k, Gigabyte Z87X UD5H, 16gb Corsair, Msi R9 290, Corsair Axi 760, Corsair 750D, 2x intel 530 240gb ssd, 2x Seagate 400gb
Older Machine amd x640, msi 760g mobo, 8gb gskillz, Sapphire 6870, Corsair hx650, Cooler master haf 922, ocz agility 3 120gb ssd || HTPC: i7 3770k, shuttle xpc z77, 16gb gskillz, Asus GTX 650 ti, intel 120gb msata ssd
https://linustechtips.com/topic/25313-my-epic-summer-project/#findComment-320806
I do not believe that the easy cap will die, but if that is a worry then do not get it. This one is similar  http://www.amazon.com/Diamond-VC500-Touch-Capture-Device/dp/B000VM60I8
https://linustechtips.com/topic/25313-my-epic-summer-project/#findComment-322313
get the easycap or dazzle they are both fairly cheap and you don't need anything too special as the video tapes are bad quality and there nothing you can really do to improve it.
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
https://linustechtips.com/topic/25313-my-epic-summer-project/#findComment-323578
https://linustechtips.com/topic/25313-my-epic-summer-project/#findComment-324603
Don't use the small easy caps, the quality is horrible, adds a lot of grainyness to the video.
But I'm guessing that the quality of VHS isn't that good to begin with so that $35 one you posted should be OK.
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
https://linustechtips.com/topic/25313-my-epic-summer-project/#findComment-324710
