First Build Planning
Go to solution Solved by Speedyv,
8gb RAM is good for right now, you can add more later if you need it. And a 750 watt PSU is good, even if you SLI. 850 is too much.
With the saved money get a ssd.
drop down to 8gb and then buy an SSD with the cash you saved from doing that... if this build is only for gaming then the rest is fine
Yes Yes Legalize Gay Marriage sure, but have you ever considered Weaponizing Gay?
CPU: I5 4690 3.5ghz || MOBO: MSI B85-G43 Gaming Board || RAM: 8GB Corsair Vengance Pro - Red || GPU: Gainward GTX770 Phantom 4gb || PSU: EVGA SuperNova 750W Gold || Case: Thermaltake Urban T31 || SSD: Corsair Force 120GB || HDD: 1TB WD Black
https://linustechtips.com/topic/252842-first-build-planning/#findComment-3464169
PCPartPicker part list: http://pcpartpicker.com/p/2yWRCJ
Price breakdown by merchant: http://pcpartpicker.com/p/2yWRCJ/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($239.99 @ Newegg)
CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler  ($61.99 @ Amazon)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste  ($6.98 @ OutletPC)
Motherboard: ASRock Z97 EXTREME6 ATX LGA1150 Motherboard  ($144.99 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory  ($71.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($119.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($51.99 @ Directron)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card  ($369.99 @ B&H)
Case: NZXT H440 (White/Black) ATX Mid Tower Case  ($109.99 @ Micro Center)
Power Supply: SeaSonic 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($139.99 @ Amazon)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Monitor: Acer G246HLAbd 60Hz 24.0" Monitor  ($119.99 @ Amazon)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  ($38.88 @ Amazon)
Keyboard: SteelSeries APEX Wired Gaming Keyboard  ($77.85 @ NCIX US)
Mouse: Razer Taipan Wired Laser Mouse  ($54.99 @ Amazon)
Other: Razer Goliathus 2014 Extended CONTROL Soft Gaming Mouse Mat ($35.00)
Other: FINGAL Swivel chair, Bomstad black black ($40.00)
Total: $1761.58
Generated by PCPartPicker 2014-11-18 01:35 EST-0500
System: Thinkpad T460
https://linustechtips.com/topic/252842-first-build-planning/#findComment-3464226
