Hey, I was wondering what size tubing will fit around quarter inch tubing.
If I'm understanding this you want to take 1/4 tube and fit another tube around the outside.
It'll depend on the wall thickness of the 1/4 tube itself so you will need to measure it with a pair of callipers and get tubing with an interior diameter (ID) of that measured size, this is just a temporary way of moving water for example to fill or drain a fish tank, you need to use fitting to adapt hose sizes cause that will leak, what are you planning to do?
https://linustechtips.com/topic/252721-tubing-help/#findComment-3462387
haha yea, just planning on wrapping primochill tubing around the kraken x61s tubes
[-] i7 4790k @ 4.7ghz [-] Asus Maximus VII Formula [-] EVGA Gtx 980 Sc [-] Corsair H105 [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/TBNRunity/saved/#savedbuild_1797964
https://linustechtips.com/topic/252721-tubing-help/#findComment-3462412
-SNIP-
Ah ok, thought you were doing some funky watercooling with old school RAM blocks, I believe they have an interior diameter of 1/4 so their exterior of them should be larger, something like 3/8" so some  3/8"ID 1/2"OD tubing will work well and since it's thin wall tubing it will let it bend easily. Just confirm the size of the x61 size though since I don't have one on hand that was just an estimate.
BTW the quote got mixed in with the post.
https://linustechtips.com/topic/252721-tubing-help/#findComment-3462471
So tubing as in internet tubing right?
Welcome to LTT! Feel free to PM me if you just wanna chat, I love conversation!
If you ever have any audio questions, wether it's software, hardware, or production and theory, feel free to ask me. Odds are I can help you, or get you help.
https://linustechtips.com/topic/252721-tubing-help/#findComment-3462783
okay, thanks! I really appreciate it.
https://linustechtips.com/topic/252721-tubing-help/#findComment-3465602
