Water cooled GPU help?
Solved by Fragsa1,
I have 2 of the same waterblocks (but for the 780) I simply have mine connected with normal fittings and clear tubes. I prefer this over the normal "SLI fittings" which you can buy. Although my motherboard has a 60mm spacing between pci-e 16x slots.
I'm not familiar with the fitting you linked to though. It looks like you have to remove the G1/4" mounting ports already on the waterblock and replace it with this block, but I don't recall seeing screws on my waterblock to allow the removal of the fitting holes though.
A key thing to note is the spacing of your cards on your motherboard. That mounting block lists a 40mm requirement.
