So I've got a problem with a friends PC I built.
He has shitty.unreliable electricity where he lives, so keep that in the back of your head.
He also has a lower end PC, fx4300/7770.
Supposedly while there was a windows update, his breaker blew and shut all his power off, now he's getting a screen with an error "OLEAUT32.dll" is missing
This happens in safe mode aswell.
Any ideas of steps I should take to diagnose this?
https://linustechtips.com/topic/252029-windowshardware-issues/
If you still have the Windows 7 install disk, pop that sucker in and go into recovery mode. If you don't, then get an iso from the microsoft website(or your preferred torrent site) and put it on a usb(or disk).
https://linustechtips.com/topic/252029-windowshardware-issues/#findComment-3453928
If you have the recovery disk, boot to that. There are several options there that can help. Since you're unable to boot, try running "Startup Repair" and see if that corrects it. If not, use the Command Prompt to run SFC /SCANNOW and see if it replaces the file.
CompTIA A+ Certified
"We are all cups, quietly and constantly being filled. The trick is knowing how to tip yourself and let the good things pour out." - Ray Bradbury
https://linustechtips.com/topic/252029-windowshardware-issues/#findComment-3460712
you can try to restore it using an install disk, and trying the startup repair,  or system restore.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/252029-windowshardware-issues/#findComment-3461956
you can't do SFC /Scannow from the install disk, and i hate it.
https://linustechtips.com/topic/252029-windowshardware-issues/#findComment-3461960
Actually you can. I detailed the steps in another post on here. I can't link to it right now because i'm on my phone.
https://linustechtips.com/topic/252029-windowshardware-issues/#findComment-3462652
Oh?
When you get home, i'd like to see it.
https://linustechtips.com/topic/252029-windowshardware-issues/#findComment-3462715
So this is the link to the post where I explained it:
http://linustechtips.com/main/topic/251600-my-laptop-keeps-on-locking-up-what-could-it-be/?p=3460796
But if that doesn't make much sense (I hardly proofread my posts) I found a great website with instructions as well.
http://mikemstech.blogspot.com/2011/12/how-to-perform-offline-system-integrity.html?m=1
https://linustechtips.com/topic/252029-windowshardware-issues/#findComment-3463725
Makes sense.
I will have to give it a shot next time this comes up. thanks.-/
https://linustechtips.com/topic/252029-windowshardware-issues/#findComment-3463919
