Hi , I wanted to build a rendering Pc for my interior Design project using 3Ds Max and Google Sketch UP . i have already picked my CPU , Ram and Motherboard . so now i am thinking my graphic card . I want use GTX graphic not quadro.
i want to use this PC as a gaming rig and rendering work station.
Motherboard : ASUS ROG Ramapage V
RAM             : Gskill 3200MHz 16G kit
CPU             : i7-5960X
Graphic        : ?
PSU              : Corsair AX860I
https://linustechtips.com/topic/251493-rendering-pc-build-guide/
If you're at all serious about rendering, get a quadro. (or equal powerhouse workstation-grade gpu) If not, and rendering is something on the side but still important, get the fastest gpu you can afford.
CPU: Ryzen 5800X | GPU: RTX 3080 FE | Board: x570 Aorus Master | RAM: 32GB GSkill TridentZ | Case: Phanteks 719
https://linustechtips.com/topic/251493-rendering-pc-build-guide/#findComment-3447067
