Hi everyone,
I want to upgrade my current rig for the upcomming game "far cry 4" , I have a budget of 380$ , what will I benefit more from in games like farcry? I have a 144hz panel so I want the most fps possible
Current rig :
FX-6100 @ 4.3Ghz
GTX760 Gaming by MSI
8Gb ram
couple ssd's and hdd's + 600watt power suply
I was looking at buying a 4690K and a descend OC motherboard since I have a descend watercooler but I dont know or that will boost my fps and quallity that much.
6600K  |  16GB HYPERX  |  GTX1070 FE  |  Z170X-UD3  |  AIR540
Respect the past, Embrace the future.
https://linustechtips.com/topic/251133-need-help-upgrading/
I would buy a r9 290x lightning with that money.The gpu is not the best and if you will the cpu you may see a very small improvement
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/251133-need-help-upgrading/#findComment-3442392
