I have an ASRock Fatality 990FX Motherboard. The problem is that if I plug Keyboard and Mouse into USB 2.0 Port it disconnects and reconnects automatically. Since then I am running them of USB 3.0 port even though it is an ordinary Microsoft USB 2.0 Product. Today I received my new Wheel and I plugged it into USB 2.0 Port and the system froze without anything going on till clicking reset. I repeated it. But when I plugged into USB 3.0 no issues. Now comes USB 3.0 Issues. From my external HDD if I try to read more than a 4 GB file from USB 3.0 corruption occurs. Writes are okay. Reads are okay only for files less than 4 GB Size. So for larger files to be read from my External HDD USB 2.0 is used. Hope u guys understood. Why is all this things happening ? Thanks.
| CPU: Intel Core i5 8400 | Motherboard: MSI Z370 PC Pro | CPU Cooler: CM Hyper 212 PLUS | GPU: Zotac GeForce GTX 1070 AMP! Edition | RAM: G.Skill Aegis 16GB DDR4 2400 MHz | PSU: Corsair VS650 | SSD: SanDisk SSD Plus 120GB | HDD: Seagate Barracuda 2TB | Monitor: Dell S2240L | OS: Windows 10 Pro x64 |
https://linustechtips.com/topic/251081-usb-port-issues/
Why no help ? Somebody help to clarify the issue.
https://linustechtips.com/topic/251081-usb-port-issues/#findComment-3449643
