high temps
Go to solution Solved by Clyne,
It's stock cooler, what did you expect........
45C is fine.....
so i just finished a build and it is a i5 4690K with the stock cooler and im in the bios and its running at 45C is that ok its been that way for about 5 min now and it seems to be stable there.
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/250853-high-temps/
Ergh that seems pretty high for idle.
Try reseating the cooler and use a better thermal paste if necessary.
Why didn't you get a 212 EVO from the first place?
It's like $25.
#SAMSUNG  "provided us 4 1tb ssds so we could run the whole site off solid state." - LinusTech
#GALAXY
#ATIV
https://linustechtips.com/topic/250853-high-temps/#findComment-3439093
