Cooler Master Trigger (Green Switches)
I was looking at getting the CM Storm Trigger in the MX Green switches after watching Linus's CES vid, I haven't been able to find that exact keyboard on Cooler Masters Website. If you look in Linus's video, you can see it looks like the bezel on the keyboard is all black unlike on Cooler Masters Product page and store show the older style with the grew bezel around it.
Here is the link to the part of the video that he show's:
If you notice the keyboard looks like it is all black without the silver colored part on it.
http://www.cmstore-usa.com/trigger-m...-green-switch/
http://www.coolermaster-usa.com/prod...torm%20Trigger
My question is, does anyone know if you actually get the all black bezel-ed one when you order the green one from the link I provided on their store?
Also can anyone else comment on how they like this keyboard (Aside from the switches if you have never used a green switch before or are using it with different switches)?
https://linustechtips.com/topic/2501-cooler-master-trigger-green-switches/
It'll have the silver bezel. Greens are ok, just kinda hard to press. I had a black switch keyboard and really like it. I would say find a green and type on it and see what you think before getting one.
AMD Phenom II 955BE 4GHz@1.4v
Corsair H100 w/ Silverstone AP122
Gigabyte 990FXA-UD3 NB@2600MHz
G.Skill 2x4GB 7-7-7-21
XFX HD5870 Crossfire
128GB OCZ Vertex 4
2TB WD Green Raid 0
Corsair AX850
Cooler Master HAF 912 Advanced
It's not out yet. Chances are the Trigger in the video was black because it's not a finished product yet. The one that goes to market will probably look like all the other Triggers.
This. The color scheme of the current trigger fits more with the non-back-lit key print, so it's unlikely they'll do away with the black backing. Although we don't really know for sure until it comes out.
...but the current Trigger is also backlit. I think the green would look pretty good with the silver, myself.
