So I was using my pc last night all was going well.... I went to turn it on today and I get no signal, I unplugged it let it drain then restarted it. No signal. I unplugged it and pulled the battery off the mobo left it for about 10 minutes went to start it. No signal , so I unplugged my video card and took it out and use on board graphics. No signal . Any suggestions? Anyone having this issue , I haven't gotten any beeping codes.
Computer Eqiupment:
https://linustechtips.com/topic/249675-no-signal/
check cable and monitor could have frayed and the latter could have a solder destroyed
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/249675-no-signal/#findComment-3423983
Not the monitor , I used both my hdmi tv and dvi monitor , about the latter solder ?
Computer Eqiupment:
https://linustechtips.com/topic/249675-no-signal/#findComment-3423996
It's also recurring , normally I just turn it on and off it'll eventually start. But I would like to fix the issue
Computer Eqiupment:
https://linustechtips.com/topic/249675-no-signal/#findComment-3424009
Yes it sounds like it completely boots , the fans turn on hit 100% then you can hear them slow down to quite mode. And idle
Computer Eqiupment:
https://linustechtips.com/topic/249675-no-signal/#findComment-3424049
