fan splitter for fan controller
It seems like Akasa Apache 120mm fans pull 0.33 Amps at the typical 12 Volts, that means they use about 3.94 Watts each, I would just round that to 4 for ease of math. Without knowing the model of your case fans it is hard to tell what they pull, but 4-5 Watts is pretty typical for a fan. I would say your probably best to stick to 3 fans per header unless you can find numbers on those case fans that prove you can do otherwise.
To calculate this yourself it is pretty easy. Most manufacturers will give you Amperage specifications, and nearly all computer fans run at 12V. Simply take Volts * Amps = Watts.
Also as a heads up, some higher end, more expensive fans are much less power hungry. Noctua NF-F12's for example only pull 0.6W (12V * 0.05A = 0.6W).
