Hello everyone,
First of all, here is a picture to show you what's in my network.
The hardware :
Router : TP Link TD-W8961ND
Laptop Windows 7 64 bits
PC Windows 7 64 bits
HTC Desire on kitkat
The situation :
I use my android device to command the laptop with Unified Remote Control and the XBMC Remote control.
It's handy when I'm watching something with xbmc :).
The issue :
I can connect to the laptop at one condition. I have to disconnect and reconnect the wifi.
Then I have like 5/10 seconds to connect. If I wait too long it doesn't work.
If I don't use the connection for some time I will loose the connection and won't have the possibility to reconnect except if I disconnect and reconnect the wifi.
What's working :
I have the internet on the laptop.
I can access a ftp server created on my HTC Desire (with Es Explorer).
-> If I do that I can then acces the laptop from the phone. As like an outbund connection validated the communication between them.
I can access a shared folder on the pc from the laptop.
-> Same story than with the ftp server. Once a connection is made from the laptop to the pc I can access the laptop from the PC.
I can access my laptop with my pc using teamviewer (I think it's because it use the internet to get access).
What I have test :
Use Unified Remote Control with the PC and it works.
If I use a lan cable for the laptop it works (so the problem is related to the wifi somehow).
I tried to disable the firewall on the laptop.
Access from the PC to the laptop have the exact same issue (I tried to ping and to access to a shared folder).
I tried to disable the IPV6 on the laptop, didn't help.
I also looked in the rooter for an wifi isolation mode but there is nothing for my router which could be related to that.
I also have a Samsung Galaxy Tab which have the same issue.
The laptop has been formatted.
The router has been changed (the issue was there with 2 previous router).
The issue is there with and without charging.
Well I think that's all.
I don't know what else to test. I have already looked a few times over the internet but without any success.
I hope someone got an idea.
https://linustechtips.com/topic/249524-wifi-inbound-connection-errors/
Did you have to install a VPN or any software on the Laptop? If so i believe what it is doing is changing the network adapter to its 'Fake' virtual adapter.
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
Nope.
I have had some Acer software installed but nothing network related (I think).
I removed them all.
When I check my network interfaces I have the Wifi and Lan. That's all.
Edit : I added a "What's working" phase to give more info.
What Router do you have?
You may have to give your Phone and Laptop a Static IP address.
Check on your Router for Port Clamping open/allow port 9512 for UDP and TCP.
What os you have? windows? On the Network and Sharing Centre click on the Change Network Adapter and see if there is a Virtual or more then Wifi and Lan (Think thats what you did before but un-sure)
Check the settings in the software installed.
Update network Drivers etc
I will check it tonight but almost every question you asks have an answer in the first post :S.
Again there is no virtual network adapter.
I have a lan and wifi that's all (on the laptop). I disabled the lan to be sure.
The software don't cause the issue since I have the error with 2 softwares and windows.
I will test your option with the static IP but the ip doesn't change (I check with ipconfig if needed).
I'm sure that every time I try to connect the ip is correct.
  • 2 weeks later...
