so my skype has been like this for about 5 mins tried restarting but nothing worked
in calls my voice arrives like 30 seconds after i say something
also before anyone says i got shitty connection
3904040269.png i got a decent connection
My PC
[ I5 4690k (no oc) - Gigabyte Z97 D3H - 8GB Ram - Sapphire R9 280X Vapor-X ]
https://linustechtips.com/topic/249437-skype-connection-problem/
Skype does that quite often hence why you shouldn't use it and use alternatives such as Razer Comms, Teamspeak, etc. I had that problem before and I couldn't find a fix until after a few days it fixed itself.
https://linustechtips.com/topic/249437-skype-connection-problem/#findComment-3420818
Hey bud, Skype works fine.
My suspicion goes to our crappy ISP.
|EVGA 850 P2| |1440p PG279Q| |X570 Aorus Extreme| |Ryzen 9 3950x WC| |FE 2080Ti WC|TridentZ Neo 64GB| |Samsung 970 EVO M.2 1TB x3
 |Logitech G900|K70 Cherry MX Speed|  |Logitech Z906 |  |HD650|  |CaseLabs SMA8 (one of the last ones made)
https://linustechtips.com/topic/249437-skype-connection-problem/#findComment-3420917
i guess so but i'm having problems connecting to the skype website too...
and yay somebody else from uae
My PC
https://linustechtips.com/topic/249437-skype-connection-problem/#findComment-3420987
