Hello everyone,
Welcome to my thread. So, I'm building a PC just because I need to upgrade. I know this is like my third thread on this but I got the money now so I can actually buy it.(don't be too hard on grammar, It's not my native language)
1. Budget & Location
I'm in Romania and will be buying parts from computeruniverse.net
2. Aim
Gaming: BF4, CoD, etc. as well as rendering and streaming
3. Monitors
2, a full HD one and a 4:3 19" one(I don't know the exact resolution)
4. Peripherals
I got everything.
5. Why are you upgrading?
I got a Pentium D. 'Nuff said.
I will be buying the parts in 2 rounds, I will add on later. The ones with (2nd round) after the name will be bought in 4-5 weeks after the 1st round.
So here's what I need:
CPU: i7 4770k
CPU cooler: Swiftech H220(2nd round)
RAM: Crucial Ballistix Sport 16GB(2x8GB) 1600MHz
GPU: Sapphire Radeon HD6950 Dirt3 edition(bought)
PSU: Corsair TX650M 650W
Case: Fractal Design Arc Midi R2
SSD: Kingston HyperX 3k 120GB(2nd round probably)
MOBO: Asus Sabertooth Z87(I love it and will change ONLY if you have a very very good reason)
HDD: WD Blue 1TB(bought)
Please tell me what you think.
Thanks,
Marc.
https://linustechtips.com/topic/24877-haswell-build/
well i dont see the point of a sabretooth mainly because you can get a ROG hero for cheaper...but id personally get a cheaper mobo and put in more ram #ramdisk :)
also it depends on what programs you use but some of them can benefit from cuda cores in nvidia graphics cards....idk which ones tho...why not get a cheaper psu? like  a cx 500 or so? those are hella cheap (ofc idk the price where you are tho :D)
https://linustechtips.com/topic/24877-haswell-build/#findComment-315089
I thought the CX series wasn't modular/semi-modular, will change to that....That's why I'm getting 2x8GB, so i can upgrade later....I will be getting a 780 for Christmas.
Edit: I want the Thermal Armor, do not want to buy it separately(Gryphon) and like the color scheme.
https://linustechtips.com/topic/24877-haswell-build/#findComment-315095
The CX series is NOT modular or semi-modular, at least not the 500W one.
Don't get a lower-wattage PSU, you're going to be overclocking, right? With a H220, you better be.
https://linustechtips.com/topic/24877-haswell-build/#findComment-315106
they have the cx500m which are semi modular but i assume you will be using a 24pin and 8pin for your mobo :P
plus the arc midi has good cable management imo so i wouldnt even mind a non modular psu...it makes the area by the psu look cleaner with no connectors coming out from everywhere...just one bundle coming out..hehe
https://linustechtips.com/topic/24877-haswell-build/#findComment-315128
Yeah, the Arc Midi does have great cable management. You don't really need a modular PSU in that case. Pun intended.
https://linustechtips.com/topic/24877-haswell-build/#findComment-315144
Another thing, I want to get some lighting....what color scheme should i go with, my mobo is mostly black, the cooler is black too, the gpu same and case is (drum roll) black(ba dum dsssss)...I was thinking red, but it doesn't go with the brown chipset on the mobo...
https://linustechtips.com/topic/24877-haswell-build/#findComment-315932
Get a Corsair Link Lighting Kit, they work great... However it only comes with two like 30mm light bars so youll have to buy more and right now you have to buy another brands light bar thats compatible. I forget which but installed them in a friends PC and they work great and there color changeable.
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/24877-haswell-build/#findComment-316066
No such thing at the store I'm buying the parts from...
https://linustechtips.com/topic/24877-haswell-build/#findComment-318482
Yah, you have to buy the kit from Corsair, i don't like cathodes, horrible light.
| F@H STATS |
https://linustechtips.com/topic/24877-haswell-build/#findComment-320373
Do you guys know any PSU wattage calculator that has Haswell built in?
PSU wattage calculators are junk most of the time.
here's my formula to calculate the wattage:
number of gpu x 250w + 90w for cpu ( if going intel , if you're going amd , change 90w to 130w) + 25w ( for the rest of the computer)
tho it will fail if you buy a junk power supply , but you don't have one in your build , so you're good.
pi = 3.14159262358979323846
https://linustechtips.com/topic/24877-haswell-build/#findComment-320533
This is what I do.
Search online and see what others have run.
https://linustechtips.com/topic/24877-haswell-build/#findComment-320763
