Hello everyone,
I have recently built a gaming rig(Beginning of this year) and am thinking of going SLI since I now have the money. One problem. I can't find the same graphics card anywhere. The store I normally buy from has got the same card only it is a different brand. My question is can I run 2 of the same graphics cards if they are different brands. The card I have is:
ASUS GTX 780 OC 3GB
The one I can get is the same but the brand is Gigabyte instead of Asus. ANY help is appreciated. Thanks!
Links: http://www.msy.com.au/saonline/pc-components/11463-gigabyte-gv-n780oc-3gd-3gb-gtx-780-pci-e-vga-card.html
https://linustechtips.com/topic/248455-2-way-sli-help/
Check ebay, they always have the card you are looking for. Just look for a seller with good feedback and a reasonable price.
-Zinqs [-] i7 4790k @ 4.6 ghz [-] 2x EVGA Gtx 980 SC [-] Asus Maximus VII Formula [-] 16gb Dominator Platinum [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/Zinqs/saved/#savedbuild_1641021
https://linustechtips.com/topic/248455-2-way-sli-help/#findComment-3407761
