How to display more than 3 images in python script?
Hey, I am having trouble with displaying more than 1 image in this python script, please help?! Thanks. Here is the script. I already have 1 image and the background, please please help!
import pygame
pygame.init()
display_width = 600
display_height = 600
black = (0,0,0)
white = (0,0,0)
gameDisplay = pygame.display.set_mode((display_width,display_height))
pygame.display.set_caption('8Bit Warfare')
clock = pygame.time.Clock()
bgImg = pygame.image.load('improvedbackground.jpg')
carImg = pygame.image.load('mothership.png')
x = (display_width/4)
y = (display_height/4)
def car(x,y):
    gameDisplay.blit(carImg, (x,y))
crashed = False
while not crashed:
    for event in pygame.event.get():
        if event.type == pygame.QUIT:
            crashed = True
    gameDisplay.fill(white)
    gameDisplay.blit(bgImg,(0,0))
    car(x,y)
    pygame.display.update()
    clock.tick(60)
RIG:  CPU: Intel Core i5-4690K CPU Cooler: Corsair H80i Motherboard: ASRock Fatal1ty Z97 Killer ATX Memory: G.Skill Ripjaws Series 8GB Storage: Seagate Barracuda 1TB Internal HDD SSD: Samsung 840 Series 120GB 2.5" SSD Video Card: Zotac GeForce GTX 970 4GB Video Card Case: Corsair 780T PSU: NZXT HALE82 850W 80+ Bronze Monitor: LG 34UM95-P Keyboard: Steelseries Apex Keyboard Mouse: Razer Taipan Mouse Mat: Razer Vespula Sound: Cyber Acoustics CA-3090, Corsair Vengeance 2100 :  1998.40 Euro
@jman629 Hey man, I really need your help. You were really helpful last time it would be amazing if you could help me with this.
If not to late...
#Code with comments above are what I added.#If you want to add a fourth image to screen create new variables and functions like I did.import pygame pygame.init() display_width = 600display_height = 600 black = (0,0,0)white = (0,0,0)  gameDisplay = pygame.display.set_mode((display_width,display_height))pygame.display.set_caption('8Bit Warfare')clock = pygame.time.Clock()  bgImg = pygame.image.load('improvedbackground.jpg')carImg = pygame.image.load('mothership.png') #Loaded another image and set equal to extraImg variable.#extraimage.png will have to be created and placed in the same folder this code is in.#when creating extraimage.png you will have to set the resoltion(width,height) at a reasonable size.extraImg = pygame.image.load('extraimage.png') x = (display_width/4)y = (display_height/4) def car(x,y):    gameDisplay.blit(carImg, (x,y)) #Created another function to put image on screen.def extra(x, y):    #x and y variables made smaller so not over car image.    x = x/2    y = x/2    #Blit the image to screen like you did in the car function.    gameDisplay.blit(extraImg,(x,y))    crashed = False while not crashed:     for event in pygame.event.get():        if event.type == pygame.QUIT:            crashed = True      gameDisplay.fill(white)    gameDisplay.blit(bgImg,(0,0))    car(x,y)    #Invoke or call the extra function.    extra(x,y)    pygame.display.update()    clock.tick(60)  #Hope this helps!
import pygame
pygame.init()
display_width = 600
black = (0,0,0)
white = (0,0,0)
carImg = pygame.image.load('castle.jpg')
extraImg = pygame.image.load('extraimage.jpg')
def car(x,y):
def extra(x,y):
    x = x/2
    y = x/2
crashed = False
while not crashed:
            crashed = True
    car(x,y)
    extra(x,y)
    clock.tick(60)
pygame.quit()
quit()
It says " Error : Out of memory
 Do you know what this means?
Do you have enough memory on your system? Most likely you should have enough. Are you running 64bit python with 32bit pygame or viscera? I think they may have to be the same. Also do other python programs run? And do other python pygame programs run?
  • 2 weeks later...
I'm having a bit of trouble checking if it is the 64bit or the 32bit version,
i run on a mac. Sorry if this annoys you.
