Huawei modem problem. Need help.
This morning I can't connect to my WiFi and Ethernet at my computer. I checked my router and modem and see that the led of power ,lan 1, lan 2, lan 3 and lan 4 if the modem is on. Its usually just power power,pon, lan 1 and tel 1 which is on. I tried to power off and on , reset for 30 seconds but its still the same. Any help please .
https://linustechtips.com/topic/248090-huawei-modem-problem-need-help/
You should contact your ISP or the manufacturer of the device, they can help you a lot better with specific hardware problems
Case: Meatbag, humanoid - APU: Human Brain version 1.53 (stock clock) - Storage: 100TB SND (Squishy Neuron Drive) - PSU: a combined 500W of Mitochondrial cells - Optical Drives: 2 Oculi, with corrective lenses.
Already did. They said they will send a technician to come to my place in three days. So meanwhile ,I'm asking for help here if it can be fixed.
Ah, well as someone who works for an ISP myself...eh, no you're probably looking at a malfunctioning modem. You can do a factory reset and that's about it for options.
Damn,that means I just have to wait till the technician comes . Thanks anyway.
