Help, Air flow!
Werdna
You don't need airflow, just use the fans that come with your case and plug them in.
In the front, and out the top and back is the usual way, generally makes for better airflow as it's being directed at the CPU and GPU.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
In the pic you have so called reversed airflow. And one fan too many for it. But usually its done by having 2 intakes in front and H100i as top exhaust. With that, you can leave rear fan off completely.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
