So I want to animate a square sliding across the ground and whenever i try to do it it always curves downwards into the "floor" that I made. I have been trying to fix this but it just isn't working. If anyone knows how to fix this it would be appreciated a lot, Thank You.
post-46765-0-80495200-1415470364_thumb.p
As you can see the path curves into the (green) floor.
https://linustechtips.com/topic/246969-after-effects-path-help/
