Help, fast system suddenly really slow after rendering
Go to solution Solved by Stefano_91,
Nothing worked, I ended up formatting the computer and that seemed to work... thank you guys any way
To start, my computer has the following specifications:
Intel i7 - 4790k without overclook
Corsair liquid cooling H105i
GPU Gigabyte GTX 770 4gb
RAM Corsair Vengeance 8GB 1600MHz Performance
Power Supply Corsair CX750 M
Motherboard Asus Maximus VII Hero
I used to play Arma III in Ultra video settings with 55/60 FPS, a few days I made some renders and the computer had not enough memory and crashed twice before I could finish the render. But since then the computer seems slower and I can't get over 10 FPS on low video settings.
I tested the CPU with Prime95, MemTest to stress RAM, and GPU with kombuster, but apparently it's everything okay. Even tried changing the RAM memory slot but still the same, defragment HD's, ran anti-virus but nothing yet. Can someone help me?
  • CPU Intel i7 - 4790K   Motherboard Asus Maximus VII Hero   RAM Corsair Vengeance 2x8gb 1600MHz   GPU Gigabyte Nvidia GTX 770 4gb rev 2.0
PSU Corsair cx750m   Storage Kingston 120gb ssd + 1tb HD   Cooling Corsair 105i   Case NZXT Phantom 410   OS Windows 7
Try re-seating the ram.
My PC: i7 3770k @ 4.4 Ghz || Hyper 212 Evo || Intel Extreme Motherboard DZ77GA || EVGA Hybrid 980ti || Corsair Vengeance Blue 16GB || Samsung 840 Evo 120 GB || WD Black 1TB
Peripherals: Corsair K70 RGB || Sentey Pro Revolution Gaming Mouse || Beyerdynamic DT 990 Premium 250 Ohm Headphone || Benq XL2420Z Monitor
That does´t work, already tried it... And i tried render again but even a small imagem it takes to long, more then normal and the system gets really slow, and the temps are not more then 40 ºC
Don't really know what to do at this point......
