Big slim fans
Go to solution Solved by DJ46,
Going for the Cryorig, seems to be the best.
I'm looking for a <15mm thick fan to push air through a heatsink. It isn't that thick or dense of a heatsink, so the blade design probably doesn't matter much, but I want it to run cool and quiet.
The options I have seem to be:
RAIJINTEK Aelous Alpha - cca 10€
Thermalright TY 14013R - cca 10€
Cryorig XT140 Slim PWM Fan - cca 13€
Prolimatech Ultra Sleek Vortex 14 - cca 17€
The Prolimatech seems a bit too expensive, but if it's worth it, it's not a problem.
If you know about a bigger slim fan than these 140mm round frame ones, I would love to hear about it.
Which one of these is the best?
PC: CPU: Intel i7-4790 MB: Gigabyte B85N RAM: Adata 4GB + Kingston 8GB SSD: Samsung 850 EVO 500GB GPU: XFX GTR RX 480 8GB Case: Advantech IPC-510 PSU: Corsair RM1000i KB: Idobao x YMDK ID75 with Outemu Silent Grey Mouse: Logitech G305 Mousepad: LTT Deskpad Headphones: AKG K240 Sextett
Phone: Sony Xperia 5 II
https://linustechtips.com/topic/246766-big-slim-fans/
https://linustechtips.com/topic/246766-big-slim-fans/#findComment-3389764
