{JAVA} How to create a method to find mode?
I need my code to create an array of 10 random integers, and then I need to use a new method to find the mode of those 10 integers.
My code so far is
 public class mode{public static void main(String args[]){int[] x;x = new int[10];System.out.print("Data Array: ");for(int count = 0; count<x.length; count++){x[count] = (int) (Math.random()*10);System.out.print(x[count] + " ");}}}
I'm not quite sure how to create a new method, or how to find mode.
Edited by alpenwasser
code tags ;)
CPU: Intel Core i7 2600k | Mootherboard: ASUS P8z68v-Pro | GPU: EVGA GTX780Ti 3GB | RAM: Kingston HyperX Genesis 8GB (4GBx2) 1600mhz | PSU: Corsair AX760 | STORAGE: Samsung 840 Pro 512GB | COOLER: Noctua NH-C14 | CASE: Fractal Design Define R4 Pearl Black | Operating SystemWindows 7 Professional 64-bit |
https://linustechtips.com/topic/246663-java-how-to-create-a-method-to-find-mode/
What are y and z?
Do you have to create it as a method or can it be in the same function?
And does efficient matter?
PSU Tier List | CoC
Gaming Build | FreeNAS Server
What are y and z?
Oh it seems those are the left over variables from my other assignment where I had to talley the array. Let me edit it out.
And the goal was to create a method that finds mode.
This could be your method: and then inside the brackets you would implement it, and then return either the index to the most common element, or the value of the most common element.
int findMode(int[] array){ }
PSU Tier List | CoC
I don't have to do that "public void findMode" thing?
my bad
public static int findMode(int[] array){ }
PSU Tier List | CoC
my bad
I got these errors
mode.java:12: error: illegal start of expression
public int findMode(int[] array);
mode.java:12: error: ';' expected
I got these errors
lose the semicolon
PSU Tier List | CoC
lose the semicolon
It gave even more errors lol
mode.java:14: error: ';' expected
System.out.print(x.findMode)
4 errors
My code so far is
public class mode
         int[] x;
         x = new int[10];
          System.out.print(findMode(x));
PSU Tier List | CoC
My code so far is
public class mode
         int[] x;
         x = new int[10];
When I ran it,it seems to be missing a return statement?
Yes, you're going to need to write the findMode function, and end it with a return line that returns the max element.
PSU Tier List | CoC
Yes because it has an int return type. So you need to return an integer inside the function for things to compile.
// The basic format of a functionmodifier returnType functionName(parameters){  }// modifier (http://stackoverflow.com/a/215505/1765721)publicprivateprotected// returnTypeintdoublevoidetcYou use void if you don't want to return something, otherwise you use the type you want to return.
