BF3 input lag
Go to solution Solved by alphabeta,
^this, and motion blur
Try turning vSync off. Tell me if that works.
It happened to me when I was using wireless card but when I switched to cable problem disappeared.
Thnx for helping  but it's origin in game which make more sense since this started to happen after origin's update :)
https://linustechtips.com/topic/245801-bf3-input-lag/#findComment-3374177
man I wish EA would just see reason and go to steam :P
sudo chmod -R 000 /*
https://linustechtips.com/topic/245801-bf3-input-lag/#findComment-3374188
