Okay, in my attempts to restore the audio of my Ubuntu machine (Acer c720 running Chrubuntu w/ 14.04) I ran the command:
sudo apt-get remove --purge pulseaudio alsa-base
then the comand:
sudo apt-get install alsa-base
After doing so, I logged out and then back in to the sys, and when i went to check my settings, none of the settings were there anymore. I clicked the "system settings" button on the top right of the desktop and all that it brought up was the Printers and Software & updates apps.
Any ideas, guys? Any and all help would be appreciated. Thanks.
"I only drink the blood of my enemies, and sometimes the occasional strawberry Yoohoo."
https://linustechtips.com/topic/245354-need-help-asap/
