AMAZON HELP
Solved by infamous_last,
Customs would charge taxes
In Australia, customs duty & GST are only due if your order is over AUD$1000 excluding shipping... so you break your orders up.
OP would have to confirm the rules for kiwi land., but a quick search shows 0% duty on computers/laptops/tablets/software and most other electrical gear.
Buying overseas still represents a significant saving, and most retailers tell you to deal with manufacturer direct so you are no worse off.
