cpu power
kk thx, should i try for 5 with out increasing the power?
you can always try but there is no magic...that's why AMD bins the chips now and sell the 1.5v 5GHZ capable CPU as FX-9590...unfortunately. Anyways...above 4ghz diminishing returns in terms of performance also kicks in and with syntetic benchmark you come to realise that increasing frequencies past that point results in only very slight performance increase...every CPU architecture has a sweet spot where if you go higher it's fine but you don,t get that much more performance out of it and for AMD piledriver my own testing demonstrated that 4ghz is about the sweet spot so i'd suggest you just call it day a before you fry or reduce your cpu's lifespan.
EDIT: hummm...also looking at your profile i come to realise that you are using a very poor 970 chipset motherboard that could give way any second at anything higher than 1.4v...so i strongly suggest dialing that thing back down...
