So I tried to OC my GPU but whenever I exceed 1600 Mhz in memory core my screen either turn black or colored and my pc won't shudown unless I force it ( holding the power button )
So something might be wrong!?
P.S screen turns like that when I open Valley benchmarks
With 1600 Mhz it turned green woth black lines after 2 sec
https://linustechtips.com/topic/243987-something-weird-with-oc/
that means it is unstable dial up power limit and volts or lower the oc offset
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/243987-something-weird-with-oc/#findComment-3344839
You might've hit the OC roof of your card...
I can't get my card past 1250MHz at +3% power limit and I'm not willing to risk it...
https://linustechtips.com/topic/243987-something-weird-with-oc/#findComment-3344876
My card is 1500 Mhz out of the box and in reviews they hit 1750 Mhz
Turn up the power limit to +10% and roll back you VRAM clocks (if you overclocked it too) by 100MHz....
https://linustechtips.com/topic/243987-something-weird-with-oc/#findComment-3344925
I didn't overclock the VRAM and after I turn up the power limit by 10% how far should I go in the memory and core clock !?
Don't touch it yet...
https://linustechtips.com/topic/243987-something-weird-with-oc/#findComment-3345007
https://linustechtips.com/topic/243987-something-weird-with-oc/#findComment-3345154
Did you reach stable 1750MHz?
Oh well your "Don't touch it" phrase included the memory so I didn't try :D anyway gonna try and keep you updated
Edit: Nah I didn't but that black screen came after pumping the memory to 1750 and all I did after that was browsing fe about 30 sec before it happened
https://linustechtips.com/topic/243987-something-weird-with-oc/#findComment-3345168
